-   -   Weber re-build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/431474-weber-re-build.html)
matty74 09-21-2008 05:32 AM
Weber re-build
Hi
I Have an old set of webers from that I want rebuilt for a 3.0
Can some one tell me the following I need to suit a 3.0 SC motor
1. Venturi size - I'm guessing 34-36mm
2. idle jet size
3. air correction jet size
4. Emulsion tube size
Who would sell set shafts and floats for the weber carbs?
What else do I need??
Cheers
matt
Inter911 09-21-2008 06:17 AM
Check out Links 1 for info on jet sizes and this place has the parts...
http://youroil.net/weber_carb_parts.html
Our host likely has parts too.
Steve@Rennsport 09-21-2008 06:10 PM
Originally Posted by matty74 (Post 4192701)
Hi
2. idle jet size
Cheers
matt
Hi Matt,
The answers to your questions really depend on the engine's configuration: cams, compression ratio. exhaust system, usage, as well as environmentals. :)
matty74 09-22-2008 01:46 AM
At the moment stock 78 3.0 SC with ssi's and 2in 2 out exhaust, street and track.
Later I will put in some JEs and GE60 cams.
Steve - does your company rebuild webers? I need some one to rebuild them.
cheers
Matt
