911 ST Engine Specs
I am researching building one of the ST engine variants and am looking to the collective knowledge of this board to fill in the blanks...This is what I think I know based on Bruce Anderson's Performance Handbook and Patrick Paternie's Porsche 911 Red Book...
2.3 - 2247 cc Bore - 85 mm Stroke - 66 mm Compression ratio - 10.3 Twin plugged heads ??? Intake Valve - 46 mm ??? Exhuast Valve - 40 mm ??? Cam - 906 Case - Magnesium or aluminum ?? Cylinders - Biral or Nikasil ?? Rods - S ?? Fuel Injection or Weber 46 IDAs 2.4 - 2380 cc Bore - 87.5 Fuel injection Everything else same as 2.3 ?? 2.5SS - 2466 cc Bore - 89 mm Cylinders - Nikasil Everything else same as 2.3 ?? 2.5LS - 2492 cc Bore - 86.7 mm Stroke - 70.4 mm Mechanical injection Everything else same as 2.3 ?? Any comments and recommendations are welcome TIA...SmileWavy |
The 2,3 and all of the other ST engines were Magnesium crankcase.
They had Biral cylinders until the 2,5 liter with 66mm stroke was introduced as the very last variant. This was made possible by the 89mm Nickasil cylinders. The 66mm stroke revved faster and lessened the vibration problems in the crankshaft on the 70.4mm stroke crankshaft, which had caused flywheels to come loose. ST engines all had 10,5:1 compression ratios, though there may have been some special factory cars (916 engine?). According to Paul Fere's Porsche 911 Story: 911/20 and 911/22: 2,247cc (85mm bore x 66mm stroke) power: 230 PS @ 8000 rpm valve diameter intake/exhaust: 45mm/39mm valve lift intake/exhaust: 12.1mm/10.5mm 911/20 = injected 911/22 = Webers 911/21: 2,380cc (87.5mm bore x 66mm stroke) power: 250 PS @ 8000 rpm valve dia. intake/exhaust: 45mm/39mm valve lift intake/exhaust: 12.1mm/10.5mm injected 911/70: 2,494cc (86.7mm bore x 70.4mm stroke) power: 275 PS @ 8000 rpm valve dia. intake/exhaust: 46mm/40mm valve lift intake/exhaust: 12.1mm/10.5mm port diameter intake/exhaust: 41mm/41mm injected 911/73: 2,466cc (89mm bore x 66mm stroke) power: 275 PS @ 8000 rpm valve dia. intake/exhaust: 46mm/40mm valve lift intake/exhaust: 12.1mm/10.5mm port diameter intake/exhaust: 41mm/41mm injected |
86.7 and 87.5 mm bores were nickasil cylinders. The earlier 2.3 may have been either nickasil or chromal. I would have expected most of the ST's if not all of them were twinplugged.
Are you thinking of building one? |
Aaron,
I am thinking of building (more like have one built for me) one of these motors; either the 2.3 or the 2.5SS...The 2.3 is more correct for my car since it's a 1970 tub but the 2.5 has more power and that's very tempting...:rolleyes: Don't know what the cost differential is between building the 2.3 vs 2.5 but at the end of the day I want to remain FIA legal... SmileWavy |
2380 st motor from armando's wonderful site. Note early cam towers on 2.2/2.0 mag case http://forums.pelicanparts.com/uploa...1222032053.jpg |
According to Fere, 87.5mm and 86.7mm cylinders were Biral. He says that 87.5mm was the maximum Biral cylinder diameter the factory could use with enough reliability.
For the 2380cc engine, 87.5mm bore Biral cylinders were used with the 66mm stroke crankshaft. For 2494cc, 86.7mm with a 70.4mm stroke crankshaft was used. Porsche wanted to use the short stroke 66mm crankshaft for better revving and less vibration so they used the Mahle Nickasil technology already tried on the 917. This was the 89mm bore cylinder with the 66mm stroke crankshaft. |
http://forums.pelicanparts.com/uploa...1222041425.jpg FWIW I also have sets of 86.7 and 87.5 Mahle cylinders that are nickasil. I am not arguing that Biral was not used because I wasn't around at the time. But all of the factory documentation that I have come across stated the use of either of these two types. Also, Nickasils were introduced in 1971 which would put the use of them close to when the ST's were being actively raced. |
Interesting. Thanks for the document.
I know Mahle now makes Nickasil cylinders smaller than 90mm. I thought that when Porsche used Nickasil on the 917 with great performance, they decided to solve the 911ST problem at the same time. I would think they would not bother with the smaller bores and would go straight for the 89mm 2500cc short stroke which they knew offered the best performance. Do you have a time period for the smaller Nickasils or was this something done after the 911ST had been developed and replaced by 911 Carrera RS/RSR? |
I suspect chromal means a Biral cylinder with a chrome coating. That has been used on aircraft cylinders that are steel. I don't think you could make an aluminum cylinder with chromal coating.
-Andy |
Chromal cylinders from a Fuhrmann 547 engine:
Aluminum with Chromium plating, dimple honed to retain oil. Nickel is more oleophillic and does not need the dimples to retain oil. http://forums.pelicanparts.com/uploa...1222058532.jpg |
Hmm, Frere p. 36 specifically confirms what Max said above e.g. "as the 87.5mm bore used for racing was the maximum that could be accomodated when the Biral cylinders were used." Starkey 14-16 inconclusive on the point.
I think of Chromal as being a very early sixties concept, is it not? When was the last time they used it, did any of the prototypes have it? (other than in an airplane engine?) :) |
So the last ones to get Chromal seem to be the 917 and the ST. |
Learn something new all the time here! |
Flieger, Aaron and John, this is great information !!!
Thanks for your contribution...I'm learning alot... |
Porsche factory cars are known to try new technology between different chassis and different races. The factory would develop the technology and always stay 1 step ahead of the privateers in speed. When the factory moved on to something faster, they would sell the technology to the customer racers in the next model or race equipment package.
Anyone have an original, untouched 911ST motor lying around to inspect?;) |
Wrong guess on my part. Thanks for the explaination.
-Andy |
Do you have this type of document for the other ST motors we are discussing ?? If so, can you post them... Does anyone know what type of work the factory may have done on these cases ?? TIA |
Interesting that it specs Platinum Bosch spark plugs.
Most on this board say Copper is the way to go for MFI. |
Is this an MFI engine or carburetors?
This also is a Rally kit engine, I wonder if there were differences between cars used in rally and circuit races. |
However, The sheet posted is the formula porsche used on most of the racing engines. Diffences would have been induction and rod material. |
Anyway.. All the ST had carburetors, and i think theres was 40 IDA,s with some "slight" modifications. My car (a 1965 912 originally) has an 2,7 with 40 IDA,s.http://forums.pelicanparts.com/uploa...1224079789.jpg |
To the best of my knowledge, all the ST motors had either MFI or Weber 46mm IDAs...
Correct, either hi-butterfly MFI or the 46's were the "normal" specs for this motor type. |
Do you know "Fredrick 911" who made a DVD at the Nuerburgring Nordschlieffe with a 911ST? He also got the urge to build an ST replica. Not easy in Norway... |
I knew that there wher 46 IDA.s, i just pressed the wrong buttons... :o)
I did not knew that there where some ST,s with MFI,s. Are you sure?? Fredrik is my "brother in law" (i am not married to, but live together with his sister!) Fredrik and me are also best friends with Christer,( "Mr." raceunivers.com) who is also part of the Nürburgringfilm.I will advice all you "petrolheads" like me to visit Christer,s site! www. raceunivers.com All of you with PRE 73, are also welcome to join our PRE 73 forum: http://porschepre73.ning.com/ |
| All times are GMT -8. The time now is 04:20 PM. |
