-   -   ARP studs in mag case w/ savers... again. torque? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/431834-arp-studs-mag-case-w-savers-again-torque.html)
whackit 09-22-2008 10:55 PM
Hi folks,
I have a set of ARP studs that I was going to use (I got a great deal on them so please don't tell me i should be using other ones!) on my 2.7 RS build. My case has case savers installed. The ARP instructions recommend 36ft/lbs. Seems like a lot for a mag case. I have read all of the assorted threads on this and nobody seemed to have an opinion. Any one out there install this combo and what did you do?
Thanks.
304065 09-23-2008 07:35 AM
Factory studs are 32NM (23.5 ft-lb) so I think you are on to something here.
whackit 09-23-2008 08:54 AM
Just got off the phone with ARP. they actually recommend 38 ft lbs of torque for the studs! I'm pretty sure the case savers would hold that, they are pretty beefy. the arp rep told me that they had been tested in all applications they are listed for (he seemed like he was reading a sheet though). Anyone out there use this value?
Steve@Rennsport 09-23-2008 09:27 AM
JMHO, but I would not putting 38 lbs-ft on the studs of any mag case, no matter what inserts they might have. I don't think ARP is familiar with those engine cases,..................
whackit 09-23-2008 09:49 AM
that's what I was thinking as well. might try to sell these and go another direction if only for my own sanity.
Steve@Rennsport 09-23-2008 11:17 AM
LOL,..Thats precisely why I made the recommendations I did in that earlier thread on the same subject. :)
