Leak between cam tower and cylinder heads
Hey guys,
I just recently finished up a top end rebuild with a friend (he did most of the building and I did all of the learning) on my '87 Carrera, and there is an oil leak between the cam towers and the cylinder heads. I believe there is no solid gasket made to be in between the cam towers and the heads, so we used a pink "high tack" form-a-gasket type compound. I'm not familiar with it at all and probably have the name wrong, but my friend who has rebuilt other engines has used it in the past. Is it possible that the nuts securing the cam towers to the heads need to be re-torqued now that it's been driven a couple hundred miles? Or is there some other compound we should have used to make a gasket? Thanks for your help.
Andy - 1987 911 Carrera Coupe |
Try not, Do or Do not
Permatex "high tach" is a horrible choice for this application. Read this thread. Use these products and success is less of a gamble.
The Complete Engine Sealant Thread...
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Manassas, VA
Why doesn't our sponsor carry Threebond products?
Mark
1991 964 Polar Silver Metallic Turbo Coupe |
You might want to make sure the leak is not coming from the rocker arm shafts. When the shafts leaks, the oil flows between the cam tower and cylinder heads dripping on the heat exchangers.
1980 SC 71 Chevelle SS454 |
