stacking cylinder base shims?
Any reason not to stack the cylinder base shims? I need 1.75mm of shim so I will need to stack 3 shims (1mm + .5mm + .25mm). I have heard that some people have custom base shims machined. I would rather not wait for that though unless it's really a better way to go. Also, I'm planning to use some curil, I assume this needs to go on all 3.
I did it years ago on my engine, no leaks (from there). Obviously a single shim would be better but CurilT has served me well.
A solid platform for the cylinders and heads is paramount for engine longevity.
I would avoid stacking more than two gaskets on a street (low performance) engine. On an engine with high cylinder pressures (high compression or turbo) I would limit the gaskets/spacer to one. The 4.0 engine we just just built had no base gasket. This required that we dimension the engine on paper before the cylinders and pistons were made. |
so does anyone know where to get a .75mm base gasket or have a 1.75mm one made?
PS. Henry your stud kit is great! |
Totally agree with Henry,....two gaskets is maximum and I never do that on a high-compressiopn or Turbo motor.
In some cases this is a real PITA since one sometimes needs to machine the bottoms of the cylinders to juggle deck height, CR and the need for a single base gasket. |
Thank you Henry and Steve. I will stack the two copper gaskets.
Head volume.....
You should have your cylinder heads CC'd so that you will know just how much volume you will need to regain. I am gathering parts for a short stroke engine for my SC and bought a set of twin plugged Carrera cylinder heads that had supposedly been cut. When the CC numbers came in on these heads, they were actually a half CC larger in volume than a single plug Carrera head. Don't take away compression if you don't have to do so!
I had assumed that the original motor came with the 0.25mm gaskets, but I just found one in my teardown pile and it is 0.5mm. I had 0.020 removed from the heads (0.5mm) so do I need to use the 1.0mm gasket instead of 0.75?
In other words, do you always add back in gasket material what was removed from the heads or is it OK to be 0.25mm short? This is a bone stock 82 Euro 3.0 with 9.8:1 compression. |
Base gaskets are used to set & adjust deck height and you really need to measure that value for yourself to know what combination of base gaskets to use. |
Also, were there any motors delivered from the factory with 0.5mm gaskets? I assumed they all had 0.25 as stock. |
I have stock 9.8:1 Euro 3.0 pistons. I will CC the heads when they get here Monday, get 4 deck height measurements, do some math, and report back. My current deck height measurement at the flat section of the piston only, with 0.75mm of gaskets installed, is 1.25mm.
The issue is remaining compatible with pump gas so you do not have more serious issues later on. You may need a timing adjustment if you find the CR is bit high. These engines tend to run somewhat lean on US ethanol fuels that exacerbates any tendency for detonation. Shoot for 1.00mm,......040". Too much deck height makes the engine more prone to detonation, too. |
| All times are GMT -8. The time now is 03:49 AM. |
