-   -   old style ring compressor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/433386-old-style-ring-compressor.html)
kodioneill 10-01-2008 02:04 PM
doe's anyone know where i can purchase the old style ring compressor? it's a 3 piece set with two parts ( like crescents ) that fit into a round hollow handle.
it was also used on air cooled Volkswagen engines.
YTNUKLR 10-01-2008 02:24 PM
I recommend the ARP ring compressor. They are sized for only one piston size, but they work perfectly. and it's American-made.
http://store.summitracing.com/partdetail.asp?part=arp-901-9000
I have the 80, 84, 90, 95 and 98mm versions and so far that's done every motor I've built.
kodioneill 10-01-2008 02:49 PM
do you like the method of installing the pistons in the cylinders first then installing the wrist pin?
i prefer installing the cylinder over the piston with the piston connected to the rod.
YTNUKLR 10-01-2008 02:56 PM
Yes I like to install the pistons into the cylinders as a unit then slide the assembly onto the head studs where you then align the rod and knock the wristpin home. I think the other method (piston on rod, slide cylinder on) does not give a good sense or "feel" of how much force you are exerting on the rings if it is not perfectly aligned. I know that's how the Porsche factory did it but I feel the 1st method is superior
kodioneill 10-01-2008 03:08 PM
thanks for your input
silver911rdb 07-23-2016 01:44 PM
I know this is an old post but I'm looking for the ARP 98mm ring compressor YTNUKLR recommends above. I can't seem to find it and it's not listed in the APR website. What are you guys using for 98mm ring compressors? I'm having a heck of a time installing my pro seal rings with my old school ring compressor. It's just not going to happen with my compressor.
Any ideas? thanks
YTNUKLR 07-23-2016 02:53 PM
Wiseco just as good.
https://www.hptautosport.com/products/wiseco-tapered-piston-ring-compressor-98mm-bore-rcs09800
faapgar 07-23-2016 03:22 PM
ring compressor tool
I have Hazet ring compressor tool which is adjustable from 75mm-104mm I have used for 40 years.Pricey when I bought it but one tool does them all.Fred
silver911rdb 07-23-2016 04:48 PM
YTNUKLR...thanks! That's exactly what I was looking for.
