Weber 40's on a 2.7 CIS
I would like to replace the CIS with Weber 40's on a 1974 2.7? What size choke, emulsion, jets ect should I be using?
This is going in a dedicated track 914-6. The 2.7 is stock w/ CIS cams. The webers are currently on a stock 2.0E so I will need to open them up I am assuming. Thanks David |
David,
Put in: 34mm venturies F26's 180 AC's 150 mains 55 idles With 3.5 psi of regulated fuel pressure, make sure the float levels are perfect. :) |
Thanks Steve.
| All times are GMT -8. The time now is 06:01 AM. |
