-   -   2.0S Nitrided rods (http://forums.pelicanparts.com/911-engine-rebuilding-forum/433722-2-0s-nitrided-rods.html)
tom1394racing 10-03-2008 12:07 PM
2.0S Nitrided rods
I just pulled apart a 69S long block. The connecting rods have a large "S" that appears to have been written with a white permanent marker.
Are these the special nitrided early S rods?
304065 10-03-2008 01:31 PM
Are they black in color?
tom1394racing 10-03-2008 05:16 PM
Here's pics.
Not black....But clearly factory marked as "S".
Must be something different between these and standard 2.0 rods.
http://forums.pelicanparts.com/uploa...1223079271.jpg
http://forums.pelicanparts.com/uploa...1223079327.jpg
BURN-BROS 10-03-2008 07:22 PM
Tom
Those are the "S" rods. I have seen them in different shades from black to about what you have pictured there.
Shoepop 10-03-2008 08:27 PM
Yes, only early 2-2.4 liter S were nitrated. My guess someone other than factory marked them with white S.
BURN-BROS 10-04-2008 07:39 AM
The white "S" marking is a factory marking usually found on the 2.0 S rods.
tom1394racing 10-05-2008 12:46 PM
Somewhere I saw reference to "the special 2.0S nitrided crank".
Is there a difference between the 2.0S crank and the standard 66 mm CW crank?
I thought Porsche had all their cranks nitrided.
Shoepop 10-06-2008 08:27 PM
No
