-   -   changing non mfi 911S cams into 911S MFI cams (http://forums.pelicanparts.com/911-engine-rebuilding-forum/434355-changing-non-mfi-911s-cams-into-911s-mfi-cams.html)
blau911 10-07-2008 11:04 AM
Guys,
I am getting ready to put together a 2.4S motor with MFI. The only problem left before going ahead and putting it together is that I have a set of non mfi 911S cams and need a set of MFI 911S cams.
I spoke to a sales rep at Webcam today, and she advised that Webcam can simply weld on the extra drive so it will work for the MFI. Price is only $150 which is a lot cheaper than buying new ones. Has anyone done this? Is they any downside?
Bobboloo 10-07-2008 12:01 PM
Welding works but why not just tap them and bolt on an extension?
sww914 10-07-2008 08:50 PM
It does need to be timed AFAIK, it may be worth it to just pay the guy. I wouldn't know where to set it?
BURN-BROS 10-07-2008 09:51 PM
Camgrinder may sell you a bung that bolts on to the end of your cam. you will need access to a lathe to machine a pocket and tap two holes. No timing of the bung is necessary, that is done with the pulleys. I have converted a couple of cams to mfi with no problems.
blau911 10-08-2008 12:21 AM
Don't have access to a lathe. Considering the amount $125-150), I would just assume let a seasoned cam specialist do the work. Thanks for the input.
