-   -   re curve distributor necessary? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/434726-re-curve-distributor-necessary.html)
whackit 10-09-2008 11:18 AM
hi folks,
As some of you likely know by now I am rebuilding a 2.7 motor with euro RS pistons (8.5:1) and E cams. I have the original dizzie from the cis motor. Do I really need a recurve? Reurve prices from all the usual suspects run around $400. That plus a new cd box and pertronix is getting into crank fire territory...
Steve@Rennsport 10-09-2008 06:18 PM
Yessir, you should have the CIS distributor recurved if you want maximum throttle response and performance.
IMHO, its not only well worth the money, but it runs decidedly better compared to crank-fire distributorless ignition systems.
RoninLB 10-11-2008 06:24 AM
will you be using carbs ?
al lkosmal 10-11-2008 08:59 AM
assuming that you're using carbs, why not look for a distributor from a 2.4E motor? Will be cheaper than recurving and you get to keep your CIS dizzy to sell and offset the price.
whackit 10-11-2008 07:17 PM
yes using carbs...
Brant 10-11-2008 08:20 PM
Steve,
theoretical question
how would you feel about a locked down distributor on a race only motor that never see's below 4K?
I'm debating recurving a 2.4T or not, for a 2.1 race motor I'm in the middle of.
my gearing allows 5K exits from all corners. (unless I really screw up something)
brant
Steve@Rennsport 10-11-2008 11:24 PM
Originally Posted by Brant (Post 4233208)
Steve,
brant
Brant,
If its a single-plug motor, you'll play hell getting the engine started w/34-36 deg advance. Twin-plug engines do better @22-26 degrees but high compression ones can bite back and will break the starter and ring gear.
One reason I use MSD's on such engines is that I can use a 20deg start retard feature to get it running without risking the starter and ring gear.
Brant 10-12-2008 07:19 AM
I always learn something here
thanks!
brant
