What distributor to use?
1968L 2.0L Block, RS spec heads, High comp. Pistons, Race Gas, Haven't decided on the cams yet. Track only car.
Thanks David |
Distributor
If you are needing twin plug take a look at our 12 pin distributor for the 2.0 - 3.8 911, the web site is JBRacing.com, do a search for Minkoff he has some nice pics on pelican of one in his race car and a few things to say about it. We build them in house and they work very well.
Mike Bruns |
David,
To elaborate a little, high compression on a 2.0 means deep valve clearance pockets in the piston, and deep dome 2.0 heads make a terrible combustion chamber for flame travel. You really a need twin plug distributor like Mike sells for a high compression 2.0 Lyn |
| All times are GMT -8. The time now is 07:43 AM. |
