3.0 or 3.2 Cylinders question.
I am about to rebuild a 3.0 ltr SC CIS motor, I suspect I'll find knackered Alusil cylinders.
If I got a good set of Nikasil cylinders from a 3.2 and bought new JE pistons, with 964 cams I'd have a nice motor right? No issues using 3.2 Cylinders on a 3.0? Thanks By the way, newbie! Ben |
The only difference between the 3.0 and 3.2 95mm cylinders is that the 3.0 use the circumferential sealing ring/groove to seal against the head.
The 3.2 (no seal) cylinders can be used with a 3.0 motor with no problems.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
E-85 sippin drunk
Why dont you look into JB R acing's iron lined cylinders. It would open up tons of ring choices, and they are quite the piece of work ( Bling-Bling). They can be found here : www.jbracing.com
Or there is always Ln Engineering's "Nickies" cylinders, and they can be found here: www.lnengineering.com Hope this helps...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Somehow I thought that the difference between a 3.0 and 3.2 was not the cylinders but the length of the rods and throw of the crank.
Old Tee all 911s sold |
You are correct, that's why you can use the 3.2 cylinders on the 3.0 engine.
-Andy
72 Carrera RS replica, Spec 911 racer |
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
we have a good used set of 3.2 Alusil p's and c's over here if you are interested...
pm me back - I'll contact the owner to see if he still has them. I don't know how much he might want. |
On a similar topic, say if one wanted to keep the 3.2 pistons. Any issues with this?
I understand the gudgeon pins are a different diameter between 3.0 Vs 3.2 To get around this, would the solution be simply to knock out the small end 3.0 rod bushings, replace and get a machine shop to adjust specifically for the replacement 3.2 gudgeon pins? Does that sound daft? Any obvious issues with that? |
Max Sluiter
IIRC, 3,2 liter rods are narrower than the 3,0 liter because Porsche made the crank throw shoulders wider to retain stiffness when the stroke went from 70,4 mm to 74,4 mm. The wider shoulders meant less bearing area to squeeze the rod onto.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Wer bremst verliert
This is exactly what I did. Then slapped a supercharger on top.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
