-   -   911 piston casting numbers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/439771-911-piston-casting-numbers.html)
Flat6pac 11-06-2008 12:58 PM
I need the list of numbers of the casting on the inside of the piston that tells me exactly what the piston is.
There is also numbers on the outside of the cylinders cast in that should have a description as to what the numbers and++ signs mean
Any help is appreciated.
TIA,
Bruce
ajwans 11-06-2008 03:04 PM
Tom1324racing posted a list some time ago, use search to find it.
andy
tom1394racing 11-07-2008 03:37 AM
Here's the current version of my listing.
I have pics of most of these if you need help in identifying your pistons.
http://forums.pelicanparts.com/uploa...1226057789.jpg
Flat6pac 11-07-2008 03:42 AM
pistons
Thats the list I was looking for. I have a couple that are not on the list to add to it.
Thanks for the help
Bruce
tom1394racing 11-07-2008 06:01 AM
Please let me know the ones you'd like to add and I'll put them in.
DIEGO nasti 12-03-2008 08:06 AM
I need help, a have a 911 sc 1981 german engine, that i'm rebuilding .would like to know which piston to use regar to hp original piston are 95L70++ and 2nd. set are 95P36++ , i'm using the same 911 sc cylinders.
thanks
tom1394racing 12-03-2008 02:25 PM
The 95P36++ are Carrera 3.2 pistons. They will not work with your stock SC crank and rods. You would have to have the wrist pin ends on the rods modified to work with the 3.2 pistons.
The 95L70 are the correct 3.0 SC Euro pistons for your motor.
Cornpanzer 12-29-2008 06:31 PM
Anyone know what a 95P30 W2 is? I have some 95P30 RSR pistons and then I have the W2 version that has a huge dome on them.
http://forums.pelicanparts.com/uploa...1230604271.jpg
http://forums.pelicanparts.com/uploa...1230604290.jpg
tom1394racing 12-29-2008 07:12 PM
The 95P30 W2 shown in your pic is the 10.5 CR.
The standard 95P30 is the non CIS 9.8 CR
9.8 CR
http://forums.pelicanparts.com/uploa...1230606607.jpg
10.5 CR
http://forums.pelicanparts.com/uploa...1230606703.jpg
Cornpanzer 12-30-2008 05:32 AM
Tom, thanks for the pics and info! Excellent!
I guess we should correct the spreadsheet
Now, the big question...does anyone have a single they can part with so that I can make a set?
tom1394racing 12-31-2008 11:01 AM
Here's an updated/corrected version.
http://forums.pelicanparts.com/uploa...1230750080.jpg
210bhp 01-02-2009 03:38 PM
Tom
Could I ask if you have a similar ref list for cylinders.
I have
90ZN2 W1
90ZN2 W2
854/1B
854/2B
and would like to find out what they are
Regards
Mike
tom1394racing 01-02-2009 04:44 PM
854/1B
854/2B
These are both 90mm (2.7 liter) KS Alusil cylinders.
90ZN2 W1
90ZN2 W2
These are most likely 90mm (2.7 liter) Mahle Alusils.
Check to see if the inner bore is slightly magnetic. If the wall do not attract a magnet (like the KS cylinders), they are Alusil.
If they attract a magnet, they are Nikasil.
210bhp 01-02-2009 04:51 PM
Thanks Tom
Regards
Mike
