-   -   Hex nuts removal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/440419-hex-nuts-removal.html)
coxy 11-10-2008 12:35 AM
Hex nuts removal
Been lucky so far with the exhaust studs but having some trouble with the hex nuts, whats the best way to remove these.
tom1394racing 11-10-2008 02:48 AM
Heat them up to cherry red with a map gas torch. Let them cool and soak them with penetrant. Get a good grip with a a hex head wrench and hope they don't round off.
If they round off, you can use a dremel cut off wheel to split the nut and chisel it off carefully with out damaging the head stud.
Good luck.
88911coupe 11-10-2008 09:58 AM
PB Blaster applied over a couple of days along with some tapping with a small hammer to try and break the old corrosion. Used dremel on any really stubborn nuts.
