-   -   CMW Heads (http://forums.pelicanparts.com/911-engine-rebuilding-forum/441035-cmw-heads.html)
cbrdonny 11-13-2008 06:07 AM
CMW Heads
Anyone using the CMW D-Port Heads in an N/A application, or were they specific designed for forced induction engines? I have read articles about the 9M heads and the power gains when coupled with proper tuning. While searching the net fighting a bout with insomnia I came across CMW and can't help but seem interested due to their background in the P-Car world.
TimT 11-13-2008 02:22 PM
The finish machine work of CMW heads leaves a little to be desired.
petevb 11-13-2008 11:19 PM
I've never used them, though I do have dynos of CMW heads in NA applications vs the 9M stuff. The CMW make very good power (over ~400 hp in a 3.9L), though probably not as good as the 9m head cam combo. When I looked I felt the 9m were likely superior, but the exchange rate made them prohibitive. That just got much better, however.
Heads seem to make sense over ~350 or so hp, though I understand engine longevity at those power levels does begin to suffer regardless of what you do.
chris_seven 11-14-2008 12:17 AM
I am quite interested in the idea of D shaped ports and I have heard that they work well on 2.0 litre engines but have no experience.
has anyone tried them on early NA motors?
kanna 11-14-2008 11:41 AM
I use the CMW heads on my 3.2 short stroke. I have seen the older heads (about 4 years ago and they were not that clean as far as machining. The newer ones (at least the set I have) are perfect. And yes they make serious power.
http://forums.pelicanparts.com/uploa...1226691665.jpg
http://forums.pelicanparts.com/uploa...1226691681.jpg
Jeff Alton 11-14-2008 12:34 PM
Details on that motor?
kanna 11-14-2008 03:31 PM
Well I'll tell you a bit....
70.4 stroke 98 bore
cam specs....TOP SECRET!
CMW heads twin plug
11.5 comp.
Billet crank
Pauter rods
Haltech E11vII engine mngmnt
Jenvey throttle bodies
Full sequential injection direct fire spark
Dyno'd waaaaay over 100hp per liter at 7400rpm
kanna 11-14-2008 03:33 PM
Oh yeah I almost forgot....car weight is 1982lbs wet with driver
cbrdonny 11-14-2008 05:11 PM
Kanna, does it still make you giggle like a school girl when hammering the throttle?
Thanks for all of the replies, I just wanted a non-biased opinion without all of the sales rhetoric. Thats why I love Pelican........
kanna 11-14-2008 05:12 PM
Actually it makes me giggle more when it pulls 3 g's thru the kink at Road America.
Jeff Alton 11-14-2008 08:50 PM
Cool, love my Jenveys too!
Billet crank, hmmm interesting.
What are you running for exhaust?
Very cool looking car, sounds fantastic!!
Cheers
kanna 11-15-2008 03:02 AM
Used the FabSpeed headers for a while. Now have our own installed. Went thru a few design changes, and the final design gained 6hp over the FabSpeed.
Jeff Alton 11-15-2008 09:59 AM
Are you marketing these headers? I may be interested for my 3.4.
Cheers
kanna 11-15-2008 03:47 PM
Not at this time. A bit more dyno time on a variety of engine displacements so I can judge specific gains.
Facey 11-15-2008 07:35 PM
i love it, over 100p/L outta these air cooled beast is impressive
tom84930 11-16-2008 11:01 AM
This thread started out as an inquiry into CMW heads, then strangely morphed into something about school girls. Could we get back to CMW heads? I for one would like to know what the Pelican brain trust thinks about them. Thanks.
cnavarro 11-16-2008 03:42 PM
I have had a bunch of customers I have modified their Nickies to run their GT2 sealing rings that are specific to the CMW heads and I have never heard a complaint about them (other than the machining, which was many, many years ago and I have not heard since).
kanna 11-16-2008 05:28 PM
And what is wrong with school girls? (-;
OK, on the CMW side, the problem with getting lots of responses about them is the fact that there aren't lots of them out there.
Many people weight the power gain against the $$$$ loss and stick with having work done on thier stock heads.
I have over $5000 in my set, but the car is built to run SCCA GT2, and I wanted every possible hp I could find. If you watch the GT2 class during the Runoffs, you'll
understand. If you leave anything on the table.....you lose.
I did run 2 different sets of pretty tricked out stock heads, and I can tell you that neither set made the usable power and torque that the CMW heads made.
