Enlarging the displacement in 3.0SC engine ?
Hi there,
I am planning to stroke my 180hp 3.0sc engine and starting to collect information of the good combinations. the special interest is in Motormeisterīs 3.0 to 3.8 Big Bore Stroke Conversion Kit => 6-New 3.8 Forged Billet Pistons 6-Biral Steel Lined 3.8 Cylinders 6-New Light Weight 3.8 Writ Pins 12-Spiral Racing 3.8 Piston Pin Locks Hi -Compression 3.8 Stroker Crankshaft Racing 3.8 H-Beam Connecting Rods No More Cylinder Expansion Increased Horse Power Increased Longevity Any experience of this scale displacement increase impact to rev limits etc ? how about the head...should I consider twing-plugging the current std head ? cam ? I am using the Megasquirt EFI with the engine and the use case is street & track. So all the hints are welcome regarding rear wheel power increase, torgue and driveability issues ? I donīt want built a turbo charged engine but I migt consider supercharger accompanied with 3.8 displacement if the engine block can tolerate charging. so in short all the hint, dyno chart etc are welcome :rolleyes: Br Sami (Finland) |
How many HP would you expect to get from that set up?
Hi,
I am "dreaming" a bit over 300 rwhp with decent low end torgue as well to make driving in normal traffic ok as well. Br Sami |
Do a search on Motormeister and try and find a thread that doesn't compose largely of the words "suck", "bastards", "thieves", "a$$ holes" etc...
First word of advise: I would stay away from anything having to do with Motormeister. They have a terrible and well deserved reputation going from bad customer service to fraudulent engine rebuilds. I would not even trust anything they sell. Anyways, I would use and abuse the search feature on this website, all the info is there. Here is a thread on the 3.6L motormeister kit to get you started...
http://forums.pelicanparts.com/porsche-911-technical-forum/133737-motormeister-3-6-big-bore-kit-weber-kits.html?highlight=big+bore Aurel |
Ok, got the point.. MM not the dream source (thanks regarding good hint anyway because I am not in US) . Letīs forget the source for a while and focus the basic questions to understand which kind of powerband etc I could expect if stroking to 3.6-3.8 (cam, heads porting, valves, airflow, EFI, etc....)
is +300 rwhp dreaming ? hints and considerations ? Br Sami |
You will have to ditch the intake and get an ITB-system so you can use a cam that support 300+ rwhp.
I think 3.7L is the maximum you can do with a 3.0L case, according to this thread:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/265390-maximum-bore-3-0-911sc-case.html?highlight=big+bore In his book, Wayne describes such a 3.7L motor, and that will give you 280-300 hp. Aurel |
I think I was reading that article somewhere deep in www ...if I remember correctly it was still with original cis system when he was promisin 280-300 hp.
Br Sami |
280 fwhp from a 3.6 CIS, probably possible.
Best bang for the buck is a 3.6 transplant, shouldn't cost you more than ~2-3000€ if you have a healthy 3.0 to sell. |
With that size cylinder and high compression, you will definitely need dual ignition.
what is the rule of thumb when to consider dual plugging ? any direct hints reflecting the cylinder size vs compression ?
Br Sami |
Keep the 70.4mm crank and talk to Charles Navarro at LN Engineering about the biggest pistons and cylinders he can help you fit to a 3 liter case. You will be pleasantly surprised.
Getting a 3.6 is cheapest when you start with a 3.6.
Thats the advice I got from Swedish engine builders, but on the other hand twin pluging is always a good idea, not to mension good looking. |
98 Euro octane is a bad combination for 10.5:1 IMHO. Maybe OK in a Finnish winter, but not in US weather. Single plug US max is 9.5:1 on 91 octane (RON+MON)/2 - assuming Finalnd is RON only. Twin plug anything 9.5:1 and over on US gas.
10.3:1 kompression on all euro 3.2 engines, so 10.5 isn't far off.
Indeed. :D
Thanks regarding all the encougariging hints ! :D
I prefer to stay in original 3.0L engine block (and related ID) which I am having in car registration papers. Have to short list you guidance and try to build certain combination to focus to issues which is nearby by my wallet :eek: Br Sami |
| All times are GMT -8. The time now is 03:26 AM. |
