Advice needed for MFI & S engines + genuine RS ducktail?
I am looking for a correct S motor for my recently acquired 70S, found 2 engines on ebay. Anyone know these sellers or have an opinion?
Second, is it possible (within reasons) to convert eg the 2.4T MFI for a 2.2S engine? Third, what would identify a genuine RS ducktail, was told my S has one. Big thanks in advance for any info! http://forums.pelicanparts.com/uploa...1226959324.jpg |
Take photos of the underside of the duck tail. If it has a steel or aluminum frame, it is very likely real. If all glass, not real.
It isn't hard to convert a T to an S motor, but probably easier to just buy one already built. |
The seller Fastclassics has a reputation and it's not what I would consider a good one. I've heard some nightmares from people who bought "restored" cars from him. I wouldn't buy anything used or rebuilt from him but I thought I would probably be OK if I only bought a new part from him. Well, I ordered and paid for a new clutch a month ago and still have yet to receive it.
Fastclassics..........(or so he says ) is nothing but dishonest to the bone. The engine he "did" for me was pure crap. He used worn out / mis matched throttle bodies, one from a T and the other from an E. the engine made no oil pressure. I was told that early cars "don't make very good oil pressure". He simply re-installed my old heads that were worn out and had been sitting for years. I paid him for the oil bypass modification and the oil bypass kit. The engine leaked oil so bad, I had to keep newspaper in the flat catch pan, to then change it every couple of days. When I finally gave up on the engine, I pulled it, tore it down and found that Fastclassics left out one of the green oil pump seals, didn't do the oil bypass modification.......and more crap stuff.
When I had my heads rebuilt, the mechanic laughed at the Fastclassic head work ( so-called ). I wish I had discovered Pelician before falling into the Fastclassic trap. I've since acquired another used engine and guess what??????this used engine makes very good oil pressure and runs great. |
Thanks for info, I found an original 911/02 running engine closer to me. Price was fair so I do have $$$$ over for minor refurbishing should that be neccessary. Fastclassics seem to be nothing but headaches..
http://forums.pelicanparts.com/uploa...1230921293.jpg [ducktail off, trial fitting original style decklid] http://forums.pelicanparts.com/uploa...1230921548.jpg [orig S engine was living in a 911E] |
| All times are GMT -8. The time now is 09:12 PM. |
