-   -   7 R case work complete I hope? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/442438-7-r-case-work-complete-i-hope.html)
MBEngineering 12-01-2008 05:40 AM
HI Andy
is this any good:
http://forums.pelicanparts.com/uploa...1228138733.jpg
for your educational purposes only.
regards mike
356RS 12-01-2008 08:15 AM
Hi Andy, Sounds like a fun engine. Checking line-bore with your old bearings might not give you the correct answer. Your old bearing have been worn in on the misaligned bearing bores and lets the crank turn free. New bearings might show a different story. I would hate to see you have problems during assembly. The mains looked good on my 7R case also but I had Walt at CE surface the case half's flat and then re line-bore standard. A little more work but now it's straight down the middle.
cgarr 12-01-2008 08:25 AM
When you bore the case mains you also need to do the layshaft bore and alignment and rear seal area:
http://i30.photobucket.com/albums/c3.../casebore2.jpg
haasad 12-02-2008 04:20 AM
Thanks mike, two 4.5 mm drills and if I can remember how to read a micrometer all wiil be well ( Joke)
Good advice to ensure all relevant bores are machined, thanks.
YTNUKLR 12-02-2008 06:29 PM
Originally Posted by MBEngineering (Post 4333060)
HI Andy
is this any good:
regards mike
Mike ,
What does the book say about when the intermediate shaft is a "1"? I can't see the measurement from the photo.
Thanks!
Scott
MBEngineering 12-03-2008 12:47 AM
HI Scott
there you go;
http://forums.pelicanparts.com/uploa...1228293830.jpg
regards mike
YTNUKLR 12-03-2008 12:49 AM
Thank you very much, Mike.
