B D B D is offline
B D's Avatar
Idler Arms and Tensioners
Can you use the new style idler arms with the older spring tensioner?
68 911L
Old 02-20-2009, 09:22 PM
You will need to machine some off the tensioner arm for them
to fit on the shaft alongside the wider idler.
andy
Old 02-21-2009, 02:53 AM
All the hydraulic tensioners after about 1980 were made with narrow support and a washer was made to hold the tensioner and the idler apart
If you have the wider idler, you should have the narrow tensioner.
If you have the narrow idler and a narrow tensioner, you need the shim washer
If youre trying to use a wide tensioner with the wide idler, youre tensioner is way too old
Replace it
Bruce
Old 02-21-2009, 05:20 AM
