-   -   Need help Identifying some carbs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/446211-need-help-identifying-some-carbs.html)
Cory M 12-13-2008 03:27 PM
I've got a set of Weber carbs I need help identifying. These were on a 2.4 engine but weren't stock. Can anyone tell me what I've got and what they are worth. I believe they need to be rebuilt. Thanks!
http://forums.pelicanparts.com/uploa...1229210798.jpg
http://forums.pelicanparts.com/uploa...1229210811.jpg
Steve@Rennsport 12-13-2008 04:36 PM
They look like 40 IDA 3C's but you can ID them yourself by looking at the upper stamped numbers on the left-facing float chambers,... :)
I see aftermarket main venturies but you cannot tell what their condition is unless you look inside the float chambers for any corrosion and measure the radial play in the throttle shafts.
Value is predicated on whether they need any major work or not. :)
Cory M 12-13-2008 05:03 PM
Thank you. I'll look for the stamped numbers.
Assuming they need to be fully rebuilt, how much should I ask for them? I don't need them for any of my projects.
Cory M 01-02-2009 02:46 PM
they have 32 stamped on them so I assume they are 32's, anybody know their value?
BURN-BROS 01-02-2009 04:27 PM
What does this stamped number say?
http://forums.pelicanparts.com/uploa...1230942449.jpg
andyjboy 01-03-2009 02:15 AM
Look like 40's due to the float chamber vent tubes - 46's don't have those ...
http://forums.pelicanparts.com/uploa...1230977714.jpg
- in fact I'd say they're probably 40 IDTP's
speedo 01-03-2009 11:31 AM
It also depends on how they were cared for...
Most of these are now 30-40 years old and have suffered the wear and tear of use. I notice a non-standard float bowl plug on the left side...you can tell it is a different size than the right side. I also don't see anything safety wired. Everything can be fixed with bubblegum and bandaids for a while...but eventually will need to be correctly repaired. As mentioned above, sloppiness in the shaft and corrosion are the biggest issues.
relayswitcher 01-03-2009 07:13 PM
I don't know if it's relative but the Zenith 40s have the same vent tubes on them, too.http://forums.pelicanparts.com/uploa...1231038789.jpg
