Piston and cylinder ID and question
I'm going through some of my old stuff and I'm wondering about these pistons and cylinders. I think they are 2.4S, but I'm not 100%. And I only have 5 of them.
http://forums.pelicanparts.com/uploa...1229545674.jpg http://forums.pelicanparts.com/uploa...1229545692.jpg Is it worth having these checked out and how hard would it be to find a 6th to match. |
Your picture of the piston underside shows "84p11" which is a 2.4S piston.
The piston shows "84p11+" actually. Are these worth having checked to see if they are in spec and how difficult to find a 6th?
I think it will be a challenge to find another "+" oversize one to match the other 5. The cylinder height also has to match the others. This is assuming the 5 are in good shape and in spec.
So the + means its oversized. Oh well, Ive had these for several years and I am starting to sort through some of my stuff and trying to figure out what's worth keeping.
Are the cylinders heights marked or do you just measure them? |
The Cylinders are marked. From your picture you have height group 5. The triangle on the bottom sleeve area with the 5 in it.
| All times are GMT -8. The time now is 06:28 PM. |
