1982 3.0L rebuild - need advice
Hi all,
Finally got my 73 911 and its current 2.7L transplant. I am planning a rebuild of a ’82 3.0L that I picked up tonight in order to replace the 2.7. The 3.0 will be a hot rod street and track car and I hope to hear some feedback on my current plans. Starting with a ’82 3.0 with 60k miles, I do not plan on splitting the case. The Alusil cylinders are off and not going to be reused. Instead, the following build is in order. Mahle 95mm pistons and cylinders with 10.5 cr ’84 3.2 heads with valve job, 8mm valves, springs and retainers and twin plug Modified S cam or similar from Web, Elgin or DC Twin plug with Electromotive XDI crank fire ignition Drill lower valve covers with twin plug Resize rods and new ARP rod bolts PMO 46 carbs/intakes I have more details but that is the basic parameters of the build. Any advise or suggestions is welcome. What other parts do I need to consider or coordination items that must be addressed? |
Why not throw 98mm C's and P's at it since you are already planning on replacing the stock ones...
Shawn,
I would have for just that reason except I got a deal on 95mm's, and they are Mahle and the had the c/r I was looking for, Tony |
This is a very nice package. You should have no surprises as many have built this before. I just finished a similar build but with 98mm PC set. In fact, I should be able to start for the first time tonight.
If you are going to resize rods and replace rod bolts then split the case and replace the crank main bearings as well. The stock rod bolts will be good for the rpm range that a Mod_S cam will provide. If the rods are tight I would just use them. This of course, would depend on how many miles the donor longblock has. I would make sure and measure everything. This includes CC the heads and piston crowns to verify compression and check valve clearance. I would do a dry build first (no sealants) to verify fitment and then take it apart and reassemble with sealants. If this is your first build you will notice that the build will not be entirely intuitive during the dry build. Better to take the extra time while there are no "ticking clocks" for hardening sealants. the second time around will be smooth and efficient and you are assured of getting a dry motor with the sealants. Read the ultimate sealant thread. There is much good info. |
Thanks Jamie,
All good advice. I think I am leaning to not do the rod bolts, rod re-sizing and splitting the case with 60k miles. Definitely will do a dry build and check valve clearance. Is there a simple way to cc the heads and pistons? |
You can expect something like this:
http://forums.pelicanparts.com/porsche-911-technical-forum/246563-another-rsr-clone-project-dyno-day.html?highlight=dyno+day |
Here is how I did the CC on my heads and pistons.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/422194-time-teardown-another-3-0-rebuild.html You could also do the same with a calibrated syringe and be close enough. The error would be higher due to less precise markings and the multiplication of runs. |
Jamie,
Did you get it fired up the other night? ANd did you ever cc the cyclinder and head by bolting up a cylinder and head on the lower end like the method cgarr mentioned? If so, do you just bolt up a dry-build and prior to checking/shimming for valve and piston clearance? Tony |
Today, I received the '84 3.2L heads with 40mm/38mm intake and exhaust ports. They look in good condition, but I really don't know how to tell. I'm gonna send them off to cgarr or xtreme head to do the valve job and go with TRW 8mm valves, EBS vmax springs and retainers for a little extra protection. Still need to pick up the 46 PMO's.
I have the 3.0L all torn down and today, I took the upper head studs out and cut two grooves perpendicular to the threads in one of the old studs to use as a thread cleaner. Ran thru all the head stud holes and it worked great. Now I am ready to install all 24 new head studs. I also soda blasted the engine, valve covers, cam housing, cam covers and fan and fan housing. Man they are clean are looking good, I will crinkle paint the valve covers and timing covers black which I think will look good, be low maintenance (not show dirt) and supposedly, cool better. The fan and housing will be painted too, not sure with what and not the edges of the fan that are next to the housing (to avoid clearance problems). I noticed the fan has been rubbing the housing pretty bad. Rubbed the housing for about 8" long and 2 " wide. Dunno why. Looks like a slight crack in the fan housing also, on one of the four tabs that hold the inner ring to the outer ring. Maybe weld it up? |
This will be my first rebuild and I have enjoyed all of the posts that I can find but I still have some questions. Does anyone know of any issues or things I need to consider in putting the 3.2 heads on the 3.0 cylinders?
Tony |
SPLIT THE CASE!!! its not much more work once your down that far....its not your orignial engine so you dont know much about it. my opinion your looking to do some performance mods and race it so why not change the bearings, change rod bolts, new chains, and make sure the base of the engine is in good shape..plus from experiance how do you know its only a 60k mile engine? were you told? odometer? neither of them i trust 100%. also you should perform a leakdown before you install rockers to make sure all is ok....
+++++1 as a vastly experienced poster here says, " do or don't... never try" I think are the words. I second what 175mph951 says.
Unless you don't mind frequently wondering what condition the bottom end is in... especially at 6800 rpm and wondering if this might be a $$$$$$$$$$$$$ (money) shift as its called. It is up to you in the end & it is your money, but, who likes to play russian roulet with an engine going to be asked to perform at its upper ends some times or mostly ?????????????????????????? Good luck & I hope all works out as you hope ! Bob |
Hey Tony, sounds like your moving right along.....
For those concerned, I am the previous owner of this engine and Tony is a friend of mine. I bought this car with 56k miles from the original owner and put about 6k miles on it over the last 4years. The engine runs like a sewing machine. The only reason the engine was pulled was it had developed a leak at the cam shaft O ring....most likely from lack of use. My intention was to reseal it and put it right back on the road but a family situation interupted my plans.... I expect Tony will get years of pleasure with his project.... |
regardless if its planning to be raced id change the bearings and rodbolts and chains....noone has x-ray vision...its just a precausion especially being its only a few extra hours work since the engine is all the way broken down. ive rebuilt 30 plus engines over the last few years....some from 30k all the way to 200k and i would never not split case and check everything. just my 2 cents....doent mean everything will be perfect inside but the fact is unless you check you dont know....and this car is planned to be RACED!!
175mph and 911 tweaks,
Thanks!!! and all definitely good advise. Trust me, I would love the peace of mind but this slippery slope has to have a bottom and being that it is not a full on race engine and my first track engine, I am falling on the willing to risk it side. The costs for rod bolts, bearings and chains is what, another $1,000 in parts, plus $175 to re-size rods plus I dont even know what else I would need or possible other costs. I don't mind the additional labor assuming I can follow Waynes book and not end up with a mistake or leaks, but without touching the case, the current estimate is a little over $12,000 which is close to my limit. I am thinking maybe I am a little more concerned with the 915 and possibly rebuilding that in order to reduce the chances of that big money shift. I know this thing won't shift like my G50 but I am afraid I am probably going to have to address it. I was really encouraged by rcecale "Can't shift into first" 915 rebuild thread. I am replacing all the shifter bushings and tranny fluid as Mede8er and I discussed to see if that doesn't improve things first. He has been a real help and inspiration to me to get this project underway. Looks like the 3.2 heads will work just fine so the heads were sent off today to Cgarr and I need to select springs very soon. Currently looking for advise on the valve springs to use. I have looked at the EBS vmax set, the JB Racing set and the performance and racing sets from John Dougherty. Any thoughts on these or other selections? I am also anticipating sticking with standard 9mm valves, maybe even regrind the existing if within spec. The rocker arms were also sent to Cgarr to rebush and resurface the faces in anticipation of new cams. I am not planning to do anything to the rocker arm shafts but i had two observations. First, they looked very clean but one or two of them had the slightest wear on the one side, opposite the cam and right at the oil hole. Visible and could be felt with the finger nail test. Is this typical or normal and more importantly, do I need to do anything about it? Second, one of the cups (non-threaded one) for the shaft bolt remains in the shaft and I am not sure how or if I need to remove it. Any suggestions? Does anyone ever use the rocker arm shaft o-rings? Saw our host carried them and was just wondering if they were cheap insurance. Thanks all, I am hoping to get some of the great help I have seen in so many threads on this wonderful forum. This is my first top end job and it is a little nerving considering I am making modifications and not just replacing what was there, so to speak. Tony |
I'll throw in my opinion to not split the case. Very unlikely to find any problem there. For valve springs I'd use John Dougherty's upgraded springs (performance). You need a little more than stock if you are using an agressive cam and spinning it to 7K or more. The rocker arms will make a little noise if they are worn but won't cause any other problems. You should be able to knock the cup out from the other side with a thin drift. I use the RSR o-rings and they seem to help with the leaks. Sounds like a great project.
-Andy |
Thanks Andy,
I probably won't split the case. I spoke with John Dougherty and decided on some DC40 cams and racing springs. Found some of Dougherty's unused racing springs w/ Ti retainers set for cheap, perhaps a little overkill, but the price was right. Anyone have some input or experience with this cam selection or better yet, this cam selection and a similar set-up? -Tony |
Well, the DC40 cams are on the way from John. I have almost all the parts to begin the rebuild but the nerves are a little stressed. Hmmm, what am I missing.
I have an order just about to place for the RSR rocker shaft rings, Goetz piston rings, chain ramps, carrera pressure fed tensioner o-rings, locktite 574, and Curil-T. I already have the complete gasket/rebuild kit and the head studs. Anyone have any other ideas so I can get what I need with reducing all the shipping cost of multiple orders. Thats probably funny as I bet I will have ten more orders as I attempt the build. Here is some pics of the Mahle P&C's, 10.5c/r, used but still in spec. and the 3.2 heads with the new valve job, valves and springs.http://forums.pelicanparts.com/uploa...1233206870.jpg http://forums.pelicanparts.com/uploa...1233206884.jpg http://forums.pelicanparts.com/uploa...1233206895.jpg http://forums.pelicanparts.com/uploa...1233206908.jpg http://forums.pelicanparts.com/uploa...1233206921.jpg |
Those heads look great...beautiful work on the twin plug...you need to ****can that clutch disc, however....:D
Thanks Bro,
Yeah that clutch disc and pressure plate/tob will be replaced and the PMO's should be here next week! Oh, if I missed a deal yesterday, I definitely made up for it last night ;) Thanks. -Tony |
| All times are GMT -8. The time now is 10:04 AM. |
