-   -   My 3.2SS The final Chapter - It runs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/447350-my-3-2ss-final-chapter-runs.html)
jpnovak 12-20-2008 11:09 AM
First, a link to previous posts on the build. I rebuilt the top-end due to head stud failure.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/435994-3-2ss-continues-part-iii-assembly.html
If you are just starting the engine specs are as follows.
1978 930/03 base engine
98mm Mahle PC set.
Measured 10:1 compression
DC 40-108 deg cams
steel head studs
Home-made twinplug distributor using Jaguar 12-plug cap and Burn-Bros. rotor. Thanks Aaron!
Twin-plug heads by G2 Racing. Thanks Craig!
Ceramic Thermal barrier coatings on heads and piston crowns
Dry-film lube on cams, rockers, rocker shafts, piston skirts, wrist-pins and every other moving part I could find.
TWM 3003 ITBs
MegaSquirt ECU (MSII-V2.2)
A few weeks ago I was able to get the motor back in the car. Last week I finished wiring up the motor only to find that my Crane optical trigger was not working. Late Thursday night I sorted it out. (Read: A new one was delivered by FedEx Ground).
So I connect the ECU, disable the motor, pull the top plugs and spin the motor with the starter. I was getting about 1.2-1.3bar of pressure off the starter. Enabled the engine by connecting the ECU and installing the plugs.
I was not expecting the motor to start right away. The motor took half-a-turn and fired to life. I was a little freaked out and shut it down quickly. I am not sure why. 10 seconds later I fired it up again. Once it was running I stabilized the map and it was loping along at 2100 rpm to break in the cam. It was running a too rich to explain the loping. After my 25 min cam break-in I made some more changes to the EFI map.
Here is the result:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/6SqYOT5AXRs&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/6SqYOT5AXRs&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
now I need to reset the AFR at idle, balance the throttle shafts and lean out the acceleration enrichment.
I am so stoked right now. I don't know if the high is from the unburned fuel vapors or natural euphoria.
Not a drop of oil anywhere that I can find.
cgarr 12-20-2008 11:50 AM
Excellent: There is no better feeling, at our age!
Your brave setting up a video for the first crank!
jpnovak 12-20-2008 12:00 PM
Truth be told that was after I did the cam run-in.
BURN-BROS 12-20-2008 01:12 PM
CONGRATS, Jamie!
boba 12-20-2008 03:17 PM
So, this will be out on the New Years Run and the Hill Country Rally.
Look forward to seeing it in person, excellent work.
See you soon.SmileWavy
Bob
jpnovak 12-20-2008 03:26 PM
Thanks guys. Yes, the plan is to have it on the road for the New Year's drive. I need lights, door panels and seats.
Bob, Are you headed down for the drive? We could find a location to meet off 281 if you want to come the back way.
Jamie
boba 12-20-2008 03:31 PM
I just saw the e-mail so I have not yet had time to check schedules, but I will try to fit it in. Will let you know.
Morrie 12-21-2008 04:07 PM
Woohoo!
Cupcar 12-23-2008 08:39 AM
Days like this are what it is all about!! I feel sorry for those who do not play the game.
silverc4s 12-28-2008 02:20 PM
Jamie,
Congratulations! i can't wait to share the road with you on the 3rd. I sure hope the weather holds...:rolleyes:
That is a really impressive project. I know you have untold sweat equity in that machine. You can be justly proud when your lap times pay the dividend for your work.
