-   -   MFI injector blocks for 3.2 heads. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/447519-mfi-injector-blocks-3-2-heads.html)
BURN-BROS 12-21-2008 02:18 PM
Making up a batch as I post. These allow you to MFI your 3.2 based motor.:p
http://forums.pelicanparts.com/uploa...1229897778.jpg
http://forums.pelicanparts.com/uploa...1229897798.jpg
More pics to come...I still need to bore them and machine the injector ports.SmileWavy
Clay Perrine 12-22-2008 11:18 AM
Can you make a set for 3.6L 3 stud heads?
I am buying if you do.
MBEngineering 12-23-2008 01:13 AM
HI Aaron
do you mean, something like this??
http://forums.pelicanparts.com/911-engine-rebuilding-forum/323373-mfi-injector-blocks-use-3-2-heads.html
would you like a set sending over??
regards mike
BURN-BROS 12-23-2008 07:16 AM
Mike, hope all is well! I would have bought from you had I known you were making them as I needed a couple of sets. I'll keep you in mind when I burn thru these.
MBEngineering 12-23-2008 09:53 AM
HI Aaron
I have 2 sets available now, 1 used and 1 set new. the ones on the post are the used set, (now back hear) which I had on a 3,0Lt engine with 3.2 heads and MFI.
regards mike
BURN-BROS 12-23-2008 03:35 PM
STEP 2: bore out to 41.5mm
http://forums.pelicanparts.com/uploa...1230075292.jpg
BURN-BROS 12-27-2008 09:52 AM
http://forums.pelicanparts.com/uploa...1230400317.jpg
BURN-BROS 12-27-2008 11:16 AM
http://forums.pelicanparts.com/uploa...1230405405.jpg
rs911t 12-27-2008 01:17 PM
Does the additional height leave room for the air cleaner housing?
BURN-BROS 12-27-2008 01:33 PM
Yes, height difference between SC heads and 3.2 with the spacers is about .25"
Henry Schmidt 12-27-2008 05:22 PM
Aaron, as usual your work is stellar. I look forward to owning a set. Now comes the haggling.
SmileWavy
