-   -   Case/Crank Work Summary (http://forums.pelicanparts.com/911-engine-rebuilding-forum/447676-case-crank-work-summary.html)
barney911rs 12-22-2008 05:04 PM
I've been reading a lot of threads this evening. I want to pull things together for my notes on work I'll have done down the road.
Aluminum Case (plan to build a 3.4/3.5 SS track/race motor)
1) Case Boat tail not needed
2) Case Shuffle Pin. only needed for high RPM, so in this case yes.
The SuperTec crank is a work of art, but not sure I'll have the budget for that
3) Crank knife edge, did not see a clear consesus on this.
3) Crank cross drill yes
4) Crank polish? lighten? crank plugs?
afterburn 549 12-22-2008 07:49 PM
Polish yes
lighten..if possible (?)
plugs - B.A. says never disturb them
Steve@Rennsport 12-23-2008 12:56 AM
JMHO so here you go,
1)Yessir,..its been worth 10 HP on a 3.4/3.5 for 25+ years as measured on our engine dyno. Thats a must-do for any race engine going over 7K.
2) Engines that will spend time above 7K should be shuffle-pinned.
3) Yes. This is part of an effective windage control system.
4) Yes! Cross-drill the center main to get sufficient oil to the adjacent rod bearings.
5) Each & every crank we do gets magnafluxed, balanced, micro-polished and the oil galley plugs are removed to properly clean out the passages, otherwise you've left all that debris in there.
Hope this helps,
