-   -   Mahle Alusil or Nikasil (http://forums.pelicanparts.com/911-engine-rebuilding-forum/448498-mahle-alusil-nikasil.html)
classictarga 12-29-2008 02:43 AM
Hi everybody,
I got a little problem with the identification of a cylinder. The engine comes of a 1977 911 with CIS (165HP). Some head studs got loose ans smashes 1 cylinder pretty bad. Now Iwant to get a new cylinder and I'm not sure what I got:
http://forums.pelicanparts.com/uploa...1230550306.jpg
http://forums.pelicanparts.com/uploa...1230550348.jpg
Cylinder and piston are both Mahle.
The casting # of the piston are "CO21" , "90L61" .On top of it it says "A2"
The casting # of the cylinder is "90ZN2 W6"
Almost all those Mahles are supposed to be Nikasil cylinders. That "almost" is my problem: The inner surface of the cylinder is not magnetic, so that should be Alusil.
I read a hundred threads about identifing those cylinders and I did not get any further.
Can anybody tell me by checking the pictures and the casting numbers what I got?
Thanks for your help,
Nico
Flat6pac 12-29-2008 03:48 AM
nikisil/alucil
The easiest test is with a magnet.
The Nikisil will draw a magnet slightly.
Thats always my first test so I know what Im working with for sure
Bruce
cnavarro 12-29-2008 04:18 AM
I would say it looks like an alusil.
tom1394racing 12-29-2008 08:41 AM
Those are Mahle Alusil.
I can provide in-spec replacements for both the pistons and the cylinders.
PM me with your email if interested.
classictarga 12-29-2008 11:16 PM
Hi folks,
thank you for the quick replies. I also thought it had to be Mahle Alusil, but since they are so rare, I did not want to believe, that I acutally have 2 Mahle Alusil engines at once. Al least I can start to swap parts.
Thanks again for your help,
Nico
