pcar9119's Avatar
carb venturi's
I'm building some carbs right now. I'm going to make my own venturi's for my carbs. They are zeniths. I'm a machinist so I have everything i need to do it. I'm curious though about the taper in the venturi's. Do i have to hold that taper or isn't it that important.
Old 12-31-2008, 02:39 PM
Important
Delta p, Bernoulli effect etc. It tried years ago and unless I duplicated the Venturi design it would not take throttle.
regards
Old 12-31-2008, 06:00 PM
You can use Weber chokes (Venturis) and just make a spacer. I think it was 2mm.
Lotus 23
Lotus 7
TVR Vixen
TR3
914-6 Clone
914-4
X-Runner
Old 01-01-2009, 06:41 AM
neilca's Avatar
You need to have the smallest diameter at the opening of the venturi tube. The higher speed air in the restricted section will create a vacuum to draw the gas out of the venturi tube. I made 32mm chokes for my Zeniths. This is for a 2.0 liter racing engine.
Old 01-01-2009, 07:51 AM
