Interchangable years for "thru" bolts
Do the engine "through bolts" vary from year to year. For instance, will the engine "through bolts" on a '71 911T fit on a 2.4 case that has been converted to 2.7 specs? Or will 1966 "through bolts" fit in a 1977 2.7 or even a "78 SC 3.0. Where are the cut off years and varients. I'd appreciate the info. Thanks, R:confused:
I think I figured this out on my own. 911 / 914-6 Same '65-'89 according to Proformance Products newest cat. I just got. Thanks R ! You're welcome R !
That's why I use Pelican for new parts! ;)
65-77 through-bolts have a coarse thread 78- onwards have a finer thread pitch If you want an upgrade, use the finer pitch versions (and associated fine pitch acorn nuts) - they are said to give more even torque readings. Regards, Andrew M |
There is also a difference in the washers that go on the through bolts. The early 2.0-2.4 engines use a square edged washer and the 2.7, 3.0, 3.2, 3.3 engines use beveled washers for cylinder clearance. |
