-   -   CIS conversion to Weber carbs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/449766-cis-conversion-weber-carbs.html)
jrairplane 01-05-2009 07:32 AM
I have a 74 911S with CIS and want to swap to Weber carbs. I understand this change is pretty worthless unless you also change camshafts. Can anybody tell me which camshafts to use that won't require me to change pistons?
Steve@Rennsport 01-05-2009 08:57 AM
IMHO, you don't need to change cams, but it does help a bit.
You can use either early "T" cams or a 964 profile (ground on 3-bearing ones).
Henry Schmidt 01-05-2009 09:34 AM
Steve is correct. If you don't modify the pistons (IE: change or add valve pockets) your cam choices are very limited.
If you can modified the pistons, I would recommend Solex cams for all around fun street driving.
safe 01-05-2009 01:16 PM
Would a T cam add any HP over a CIS cam? How does it compare to the 964 grind?
