-   -   Odd P&C's from 3.2 L (http://forums.pelicanparts.com/911-engine-rebuilding-forum/449927-odd-p-cs-3-2-l.html)
andrew15 01-05-2009 10:19 PM
I was just look on my shelf and found an odd set of P&Cs from a 3.2L.
With both P&Cs being marked KS, I assumed they were alusil cylinders and onto the shelf they went, but....
Cylinders have a groove for a CE ring gasket
Cylinders are nikasil (magnetic)
Pistons are not magnetic (like the iron coated ones for alusil cylinders)
Pistons have a 23mm wrist pin (so they are 3.2 not 3.0 pistons)
Did KS make a nikasil 3.2L P&C set with CE gasket?!
I have a receipt for an engine rebuild that specifies 'replated cylinders' which may explain the cylinders - maybe they are replated 3.0 versions. But that doesn't explain the pistons eing KS and suitable for nikasil.
Andrew M
tom1394racing 01-06-2009 02:27 AM
Andrew
What are the P/N's cast into the inside of the skirt or bottom of the dome?
That can help identify the pistons.
