-   -   Why the 12mm Spark Plug? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/449930-why-12mm-spark-plug.html)
YTNUKLR 01-05-2009 10:38 PM
I saw what seemed like factory 2.5 911S-T Race Heads on Ebay a while back, and the listing stated they were 12mm plugs (both). It seems silly for someone to have welded up the standard 14mm plug so I assume those were factory race heads.
I have also heard that Porsche used 12mm plugs as the secondary plugs in the twin-plugged race engines.
Why is this the case? What is the benefit to running a 12mm spark plug?
Cheers
Scott
juicersr 01-06-2009 02:15 AM
Scott, pm sent
MBruns 01-06-2009 08:17 AM
12mm
It is common practice and sometimes even 10mm, there are great selections of race plugs ie. motorcycle plugs, and the main reason is the chamber vol. in the head is not increased like with the larger plugs.
Mike Bruns JBRacing.com
manu72S 01-06-2009 08:31 AM
Exactly the same opinion as Mike
cgarr 01-06-2009 09:11 AM
I only do twinplugged heads with the 12mm second plug because you leave more material in the head and with the 12mm plug you do not have any clearance problems with the stock head stud nuts.
930gt-40r 01-06-2009 06:10 PM
Is it also good for combating cracking between the second plug and the exhaust valve seat area? This is what I have always thought to be the reason.
