-   -   Sharp edges on JE pistons (http://forums.pelicanparts.com/911-engine-rebuilding-forum/452068-sharp-edges-je-pistons.html)
jimbauman 01-18-2009 08:39 PM
The area of these JE pistons that the arrows point to is a very very sharp edge - a couple of mm above the top land at the edge of the indent. Should this be so sharp? The thin metal might create hot spots or even melt?
http://forums.pelicanparts.com/uploa...1232339870.jpg
Should this be left alone or machined to a smoother edge?
JB
kenikh 01-18-2009 08:50 PM
It is standard practice to smooth these over. A light grit sandpaper works well.
304065 01-19-2009 07:32 AM
Jim,
I did exactly that, here are the pictures in my "Jugs and Slugs" thread.
http://forums.pelicanparts.com/showthread.php?t=368320&page=3&highlight=jugs+slug s
jpnovak 01-19-2009 07:52 AM
I did the same using a fine roloc scotch brite pad in my angle die-grinder. Provide a good radius there. You can also round over the sharp edge where the valve pocket hits the center of the piston crown. John has some great pictures in his thread.
jimbauman 01-19-2009 08:22 AM
Thanks for the replies - and those are some excellent pix in the slugs thread!
JB
cgarr 01-19-2009 08:37 AM
So what are you building??
jimbauman 01-19-2009 08:40 AM
..helping a friend rebuild a stock 3.2 into a 3.4. Old cylinders were alusils so he decided to upgrade rather than have them reworked.
JB
cgarr 01-19-2009 08:57 AM
Nice: Those looked a lot like the pistons I used in my 3.4 build: Going 10.5/1? twinplug?
jimbauman 01-19-2009 09:04 AM
Unfortunately not! :-( It has to remain smoggable for California emissions, so the only other mods he can really get away with are 964 cams, SSIs (replaceable at smog time), and a Wong chip.
JB
