idler arm dimensions
I am looking for the dimensions from the little white book
for a 67S of the idler arm. What should the inner dimension of the arm itself be on the case shaft where the arm pivots? The other dimensions I'd like to know are the inner dimension of the idler sprocket is as well as the outer dimension of the idler sprocket shaft. Thanks in advance andy |
HI andy
is this of any you??? ![]() regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Perfect, thankyou. Now where do I get one of those little white
books without paying through the nose for one? andy |
HI andy
it is not the little white book you need, it is the manual; see below for sale http://www.ddk-online.com/phpBB2/viewtopic.php?t=22472 regards mike
