3 bearing cam towers
Hi All, 3 bearing cam towers 69-73 are they all basically the same and interchangable or are there subtle differences?
Some of the early ones only had 2 holes from the spray bar instead of 3. I dont know when the change was made to 3.
Probably the late 60s because a 70 I did had 3 holes for the spray bar. Bruce |
The early (2.0) cam towers have a different hole pattern on the exhaust side cam cover. I believe the intake sides are the same.
