Cam tower plug, spray bar
I'm trying to pull the cam tower spray bar plugs. I have one drilled and tapped for a 6mm bolt. Using large washers on the bottom and smaller ones on top I have the 6mm bolt through the washers and screwed into the threaded hole then tightened down a nut on the bolt to the washers. Tightening the nut the plug doesn't seem to want to move, should I use heat? I'm being careful here so I don't strip the thread I've made.
plug
Thats the method I use, some are tough, but never had to use heat though, has it pulled the tapped threads? if not keep pulling
Mike Bruns JBRacing.com |
I had mine machined out.
Well I moved on to the next tower and it came right out, although the plug left some burs and the spray bar was a sob to get out, plus put a real nice scrape mark on the spray bar. I will apply more pressure to the first towers plug. I see the host is showing the spray bar as NLA.
Got the first towers plug out, and I have another tower thats a bit biffed up so I scavenged a spray bar from it.
I see from searching that some are using 1/8" threaded pipe plug instead of the factory press fit plug. Any down side to this? |
spray bars
They are available, contact me and I will give you a Porsche #
Note...I piped taped the plug ends and of course inserted pipe plugs........next time Pc of cake
| All times are GMT -8. The time now is 09:33 AM. |
