-   -   964 Case Hardware (http://forums.pelicanparts.com/911-engine-rebuilding-forum/459619-964-case-hardware.html)
VincentVega 02-26-2009 01:17 PM
964 Case Hardware
I am preparing to seal my 964 case. Rounding up the hardware I have a question about the perimeter case nuts. The manual does not say to replace the nuts but I wonder if this is a best practice.
From the parts diagram the buts appear to be 900 076 078 01. If replaced, is a standard 10x1.25 nylock appropriate, or is this a dealer part?
Flat6pac 02-26-2009 01:30 PM
The nuts are deformed to lock, they have a taper on the top. Use them again, theyre easy to spot in the box of nut and bolts.
New nylocs will do the job too but you have to go to Porsche for the gold ones..I use the silver ones, still holds just as well.
Bruce
