-   -   3.2 camshaft timingng specs. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/459762-3-2-camshaft-timingng-specs.html)
Sophie 02-27-2009 07:41 AM
Help. The old manual that I have doesn't have the intake valve stroke in overlapping TDC that I need for my 86 Carrera . Where to look would be a great help. Thanks
MBEngineering 02-27-2009 08:30 AM
HI Sophie
cam timing for the 3.2 engine 930/20/21/25/26 is 1.1-1.4mm.
intake opens 4deg BTDC.
intake closes 50deg ABDC.
exh opens 46deg BBDC.
exh closes at TDC.
regards mike
Sophie 02-27-2009 09:20 AM
Mike Thank you so much for the answer that I needed. Now I can get back at it . Sophie
