-   -   Head Stud Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/461518-head-stud-question.html)
Number1_dog 03-07-2009 06:05 PM
Head Stud Question
After torquing my head down on Cylinder 1 to measure the Deck Height when I went to remove the head one of the Head Studs came off with the Allan head nut on it. I can't seem to remove the Alan head nut, placed it in a vice with a rubber cushion on the stud but it didn't budge.
Can I Just tighten the Stud with the Alan head nut on it to the proper torque when I assemble the Head and Cylinder?
dog
im4duke 03-07-2009 06:13 PM
I am no expert, but if no luck after trying penetrant and heat, I would cut the nut off, clean the stud, and reinstall with a new nut.
cgarr 03-07-2009 06:48 PM
What year? I hope not a mag case!
Number1_dog 03-07-2009 06:55 PM
No, not a MAG case, a 1979 SC case
TibetanT 03-07-2009 11:15 PM
I think if you meet the height specifications for the heads you should be okay. Might want to make sure you did not cross-thread the barrel nut onto the stud.
Eagledriver 03-08-2009 10:36 AM
You could try to "double nut" the case end of the stud and clamp the nuts in a vise then undo the barrel nut.
If this doesn't work I'd get another stud and barrel nut to replace it. Any engine shop should have an old stud to match whatever you have. I hope you replaced all the lower studs (they are the dreaded old dilivar studs).
-Andy
