Removal Oil Pump & Oil Pressure Relief Plugs
What do you guys use to remove the oil pump & oil pressure relief plugs from the engine case?
Mine have been removed before by someone who appears to have used a flat blade screw driver and damaged the slot.
Is there a special tool?
Any suggestions????
Need to get in there and clean the pistons and bore.
Old 06-02-2011, 06:03 AM
I had to use a punch in the slot with a hammer to get them loose. I replaced them with new ones from Pelican that have a hex head drive so you use a wrench to tighten.
Lindy
Tell it like it is or don't tell it at all.
Old 06-02-2011, 07:33 AM
After cleaning.......that's the plan.......NEW hex plugs
Old 06-02-2011, 08:16 AM
Removed mine this past week-end. Get a Drag Link tool. May have to file the blade down a bit to fit the slot. They are cheap on e-bay.
John
Old 06-02-2011, 08:57 AM
