-   -   Removing cam chain tensioner (http://forums.pelicanparts.com/911-engine-rebuilding-forum/462132-removing-cam-chain-tensioner.html)
ahdoman 03-10-2009 08:18 PM
I am going to be installing my hydraulic tensioners. How do I remove the "930..." types currently installed? I know about keeping the tension on the chains and all the details. What I need to know is how to compress these?
ahdoman 03-10-2009 08:19 PM
Sory...forgot the pic;
http://forums.pelicanparts.com/uploa...1236741594.jpg
MBEngineering 03-11-2009 01:39 AM
HI ahdoman
Just pull the tensioner off the shaft, and hold the bottom of the idler with the engine on TDC, the cam gear is on the wrong way round!!! if that is your engine, and are you selling the old tensioners and case covers??.
regards mike
ahdoman 03-11-2009 06:46 AM
Thanks Mike. The parts are going into another "backup" engine. How can you tell the cam gear is on backwards?
MBEngineering 03-11-2009 09:38 AM
HI ahdoman
a bit of info for your education
http://forums.pelicanparts.com/uploa...1236788456.jpg
http://forums.pelicanparts.com/uploa...1236788502.jpg
http://forums.pelicanparts.com/uploa...1236788526.jpg
regards mike
ahdoman 03-11-2009 04:11 PM
Thanks for the heads up Mike. I didn't rebuild this engine. I was just swapping out to the Carrera tensioners. I'm glad you caught that. So this is the side I want out?...
http://forums.pelicanparts.com/uploa...1236813058.jpg
Flat6pac 03-11-2009 05:51 PM
I would check the other side also because I can assure you that the chains were not measured for chain alignment with the center case intermediate shaft..there is no way what is there is properly measured and built
Bruce
ahdoman 03-11-2009 06:53 PM
Bruce - I checked the other side and it is correct. This is a well running 77 2.7CIS. I am preping it to install it into my 914/6. It is curently torn down to the long block but since I have to re-orient the cam gear I will go ahead and check everything else tied to the timing.
How do you measure for the chain alignment with everything assembled? I have used Wayne's rebuild book and I don't recall him discussing that. I am curious to take the cam gear off and see if maybe it has a spacer under it because the chain and gear isn't worn strange.
vreference 03-12-2009 02:02 PM
It's the chain that I would expect to have suffered, not so much the gear.
