Porsche 911 oil line
Hello,
Can someone please give me the part number for this oil? Its for a 1983 Porsche 911SC.
Thank you in advance.
Old 09-11-2021, 11:22 AM
This will do it
91110774312
Bruce
Be sure you can remove the outer hose to the oil tank at the thermostat because that nut has to come loose before you can get to the nut to change the hose in the picture.
If it won’t loosen, you’ll need to diagonally cut the nut to get it off, then hit it with a hammer and chisel.
You might need to do that to the hose you want to change.
Oil tank to thermostat hose is 91110773013
Bruce
Old 09-11-2021, 07:59 PM
Thanks Bruce, will start juicing the lines then before trying to undo them.
Old 09-12-2021, 12:28 AM
