-   -   Make sure to check your intermediate shaft alignment (http://forums.pelicanparts.com/911-engine-rebuilding-forum/464003-make-sure-check-your-intermediate-shaft-alignment.html)
jjrowe 03-19-2009 08:48 PM
Or something like that.. I just took an engine I bought for parts apart. The smaller gears to drive the chains are toast. This one has no teeth left, the other is so pointy it feels like I could cut my finder on it. How does this happen?
http://forums.pelicanparts.com/uploa...1237520817.jpg
http://forums.pelicanparts.com/uploa...1237520843.jpg
Couldn't find the teeth anywhere in the case. Hopefully they didn't find their way into the oil pump.
Jesse
76 911S
Eagledriver 03-19-2009 08:52 PM
Mechanical tensioners maybe? Maybe someone put new chains on worn sprokets or the engine just has too many miles on it.
-Andy
Flat6pac 03-20-2009 02:27 AM
There was someone the other day that the cam gear was wrong face out and there was no alignment done on building the engine. I have to admit,I never saw one that bad.
Bruce
jjrowe 03-20-2009 08:50 AM
It also looks like the chain was rubbing on the side of the main gear. I wonder if its possible to be that far out of alignment? If it is that would explain such a catastrophic failure.
The engine looks pretty clean otherwise, probably a recent rebuilt. They tried to use red locktite to seal the case and heads and there was so much it nearly clogged some of the oil passages.
- Jesse
76 911S
jluetjen 03-20-2009 10:59 AM
My guess is that old chains were used. As chains wear they get longer as each individual pin and hole wears. If you put an old chain on new bike gears you get the same thing with the sprockets wearing very quickly. As far as the uneven part, the comment about the mis-installed gear on cam shaft sounds reasonable. Did you happen to notice the alignment of the gears when took them off?
BURN-BROS 03-20-2009 12:09 PM
Damage to the gear happened when the sprocket failed. the chain was no longer aligned and contacted the gear.
T77911S 03-23-2009 09:41 AM
cam gears on wrong.
i wonder what kind of racket that made? had t be audible.
surprised it did not break the chain hitting on the gear like that and for that long.
i would not trust the oil pump.
