Santa Clarita, Ca.
FYI - 77 2.7CIS installing into 914/6.
There are 3 oil sensors on the case. Porsche PET calls both #1 & #2 a "temp switch". #3 I believe is the pressure transmitter? Here's the questions; - What's the difference between #1 & #2? and where do these wire to? (For reference; my 914/6 gauge has an oil warning light and a temp gauge). I also have a VDO Oil BAR gauge that will be added to the console. ![]() ![]()
#1 little red head is an oil light indivcator for about 7 psi
#2 is the oil temperature #3 is oil pressure, in a 77 it represents 0 to 10 bar You would want to use 911 guages so that you have pressure and temp matches sender and guage Bruce |
Santa Clarita, Ca.
Thanks Bruce. My understanding is that the 914/6 gauge is set up for the 911 resistance values.
