teveo's Avatar
Diagnostics equipment advice anyone?
Hi, I have come to the conclusion that I need to get equipment to measure co / emissions and air fuel ratio. Would appreciate some feedback from experienced users.
My goal is to adjust and tune my carb and injection systems. I would like to get an instrument that could do both co & af but it is hard to find something at a nice price.
I am considering the Innovate (I or II) for the AF and perhaps ebay for an older heathkit or similar analog analyzer for the co/emissions.
Anyone have recommendations on other / better / combi instruments?
"old cars and bikes"
== System architect & developer
Old 04-02-2009, 02:18 PM
steinec's Avatar
Tuning
So you have a carb and cis ? Must be pretty cool looking . Have you cosidered taking the car to shop with a dyno and PC interface ? Most of them can get you the data you're looking for and even help tune as well as recommend jet changes.
Salt & Pepper: '85 911 Carrera Targa Polar White; '77 930 Porsche Black
Old 04-03-2009, 01:28 PM
A gunson gastester will measure CO and not cost an arm and a leg. You can find them on eBay, not sure if you can even buy one new anymore. It uses a probe you simply stick up the exhaust pipe, perhaps a plus for you if you want to use it on a lot of different cars.
The LM1/2 are AFR meters that use a wideband O2 sensor. Would be harder to switch between several cars. These lend themselves more to permanent installation in a single car. The benefit there is that you get a continual readout of your AFR as you drive.
Old 04-04-2009, 09:40 PM
(the shotguns)
berettafan's Avatar
gunson colortune is worth having imo. coupled with some sort of fancy schmancy exhaust analyzer you can probably get pretty darned good.
Old 04-07-2009, 01:18 PM
Gunson's are still available, and from the many ebay ads, the price has increased. About $200-$250 new. They're accurate, but are only able to measure idle and off-idle CO.
http://shop.ebay.com/items/__gunson-gas_W0QQ_kwZgunsonQQ_kwZgasQQ_ckwZtester?_trksid=p 3286.m104.l1199
Sherwood
Old 04-09-2009, 12:55 AM
