Diagnostics equipment advice anyone?
Hi, I have come to the conclusion that I need to get equipment to measure co / emissions and air fuel ratio. Would appreciate some feedback from experienced users.
My goal is to adjust and tune my carb and injection systems. I would like to get an instrument that could do both co & af but it is hard to find something at a nice price. I am considering the Innovate (I or II) for the AF and perhaps ebay for an older heathkit or similar analog analyzer for the co/emissions. Anyone have recommendations on other / better / combi instruments?
"old cars and bikes" == System architect & developer |
Tuning
So you have a carb and cis ? Must be pretty cool looking
![]() . Have you cosidered taking the car to shop with a dyno and PC interface ? Most of them can get you the data you're looking for and even help tune as well as recommend jet changes.
Salt & Pepper: '85 911 Carrera Targa Polar White; '77 930 Porsche Black |
A gunson gastester will measure CO and not cost an arm and a leg. You can find them on eBay, not sure if you can even buy one new anymore. It uses a probe you simply stick up the exhaust pipe, perhaps a plus for you if you want to use it on a lot of different cars.
The LM1/2 are AFR meters that use a wideband O2 sensor. Would be harder to switch between several cars. These lend themselves more to permanent installation in a single car. The benefit there is that you get a continual readout of your AFR as you drive. |
(the shotguns)
gunson colortune is worth having imo. coupled with some sort of fancy schmancy exhaust analyzer you can probably get pretty darned good.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Sherwood |
