3.2l short stroke conversion HP numbers
I have recently done the conversion in my ride. I am wondering if anyone has values for HP after doing this.
specs: original 3.0l Non a euro with CIS new 3.2 P&C with J&E 9.5:1 compression with CIS 964 cam grind ssi's single outlet exhaust sport muffler not sure of make I am curious of what kind of HP I have now but will not be spending money on a dyon to find out. Can anyone get me in the ballpark? |
98mm pistons? 3.2 pistons are 95mm, same as 3.0 pistons. Going to 3.2 with 98mm pistons should get you around 7 percent more power. The other mods could get you some power but mufflers vary alot.
-Andy |
the money to get it dynoed? it is not very expensive...
with your local PCA they will probably have a dyno day and it'll be like $75... and a bunch of fun. |
| All times are GMT -8. The time now is 05:41 PM. |
