Upgrade to 3.2L with 964 cams
Hi,
I plan the rebuilt of my engine (1982 911sc 3L) & upgrade output power. I would like to know if a set up like this one will work with 964 cams profile ? 98mm pistons Mahle 98 P11, 9.5:1 3.2L cyl. Bore oversise & machined to fit on 3L block. Thank you Pierre |
Hi Pierre,
964 cams will work perfectly with your Mahle pistons. |
Thank you for the information Steve.
| All times are GMT -8. The time now is 06:06 AM. |
