Which Washer for Case Nut by Timing Chain?
What washer should I use for the hidden 15mm case nut located near the left timing chain? I was thinking nylock nut with a aluminum crush washer.
inside, youre talking a 17mm and I would not use aluminum or nyloc inside the engine.
Bruce |
So what is the correct setup then?
17mm nut and a wavey washer.
Bruce |
| All times are GMT -8. The time now is 07:41 AM. |
