-   -   Can REAL TDC be where the TDC tool indicates? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/469381-can-real-tdc-where-tdc-tool-indicates.html)
jimbauman 04-16-2009 04:47 PM
We're using the Stomski TDC tool to locate true TDC during an engine rebuild (cam timing tomorrow) ... never used one before. Is it normal for the TDC that the tool indicates to be about 1/32" to one side of the Z1 pulley groove? Just need a sanity check... Thx!
JB
TimT 04-16-2009 05:40 PM
Yes.
the tool indicates to be about 1/32"to one side
Are you sure its not 3/64ths off? Quite hard to get a good dimension lined up between the split in the case, and the mark in the pulley.
Finding TDC using a tool/dial gauge/screwdriver etc. lets you find exact TDC...
It also allows you to find out how far off the marks on the pulleys flywheel are..
930gt-40r 04-16-2009 10:28 PM
The most accurate is the dial indicator with degree wheel method @.050-
or that seems to be the most accruate to me
shbop 04-17-2009 03:58 PM
Anyone else using one of these to assist?
http://forums.pelicanparts.com/uploa...1240008794.jpg
911pcars 04-18-2009 12:20 AM
I haven't seen the Stomski TDC gauge, but the most accurate method uses a mechanical stop. Dial indicators, whistle indicators and screwdrivers inserted into the spark plug hole are only approximate. Near TDC, there's relativetly little piston movement compared to the rotation of the crank, and it is the crank that should be the reference.
Think of a tool that looks like a hollowed out spark plug and threaded internally with a long bolt and lock nut.
The best time to find TDC is w/o the timing chains installed. In fact, a mechanical stop can be fashioned without the cylinder head installed. Position no. 1 piston toward TDC. Insert the stop bolt assy., then thread the bolt inward until it contacts the piston. Carefully reverse rotation of the crank, then again rotate the crank slowly until the piston contacts the stop. Place a temporary mark on the pulley.
Carefully rotate the crank in the opposite direction about 360º until the piston again contacts the stop. Mark the crank. There are now two marks on the crank. The distance halfway between the two is exact TDC. If the mark is different from the existing factory mark, file a V-shaped groove to indicate true TDC and apply some white paint on it to make it more visible.
Establishing true TDC is essential to arrive at the specified cam/valve timing.
Sherwood
