correct flywheel
i have a 69 2.0 with a 215mm flywheel but i also a 72,73 2.4l with a 215mm flywheel which one would be correct and are they interchangable using the proper clutch. i think the 2.4 has a 215mm with a stage 1 kennedy clutch in it but was in when i purchased. is there a reason for doing this?
Old 04-21-2009, 09:30 AM
356RS's Avatar
The 2.4 had a 225mm clutch and is also a pull-type clutch system. The 64 to 69 "901 transmission" had a 215mm clutch and a push-type clutch system. That was changed in late 69 to a pull-type with the mag. case 911 transmission. So it would be very difficult to use the later clutch system in your 901 transmission.
Mark Jung
Bend, OR
MFI Werks.com
Old 04-21-2009, 10:31 AM
